Can't uninstall runtime engine 6.0.1
I'm trying to update a computer from a labview runtime engine 6.0.1 to runtime engine 6.0.2. I am able to install and uninstall runtime engine 6.0.2 but I can't uninstall runtime engine 6.0.1. In the control panel on "add/remove programs", I can't remove "NI Labview runtime engine 6.0.1". In fact when trying to remove it, I get a dialog box that displays the message "This action is valid for products that are currently installed". Any suggestions on how to remove 6.0.1 runtime engine before or after installing runtime engine 6.0.2?
(2,908 Views)
Jeff,
When you install the run-time engine 6.0.2, do you still see the run-time engine 6.0.1 in the add/remove programs? If so, then go and delete the run-time engine 6.0.1 folder from the installation (Shared) directory.
If you installed the run-time engine 6.0.1 with LabVIEW 6.0.1 update, try running the LabVIEW uninstaller, and select to uninstall just the run-time engine.
I hope this helps.
Zvezdana S.
(2,908 Views)
