Can't use IMAQ Generate Pulse with PCI-1407
I always get error -1074397126 Hardware not capable of supporting this function and I'm wondering if it's true or if the problem is from me when I try to configure it. Any help would be appreciate. Thanks,
Martin
(2,707 Views)
Hi, Martin,
The error you are seeing is correct - the PCI-1407 does not support the IMAQ Generate Pulse VI. As stated in the VI Help for IMAQ Generate Pulse, "Currently, only the IMAQ PCI/PXI-1409, IMAQ PCI/PXI-1422, IMAQ PCI-1424, and IMAQ PCI-1428 can generate pulses."
Dawna P.
(2,707 Views)
Hey thank you to confirm this. I searched everywhere to find the information but did not read these notes at the very bottom of the help.
(2,707 Views)
