You should be able to use MAX with LabVIEW eval. To make sure MAX is installed, go to
...\Program Files\National Instruments\MAX
If you have NIMax.exe, MAX is installed. Even if you don't have LabVIEW installed, you should still be able to open MAX from this location.
Do you get this error when launching MAX from its installation directory, or when opening some of the LabVIEW wizards that call MAX? The LabVIEW Evaluation Version gives the option of installing simulation DAQ VI's. If the complete install option is chosen, the simulation VIs are installed.
To avoid this, choose a custom install and don't allow the Evaluation Version to install NI-DAQ. After the LabVIEW Evaluation Version is installed, install NI-DAQ and include support for LabV
IEW 7.0. The DAQ VIs will now read data from your DAQ device. There is a link to the NI-DAQ download page below.
NI-DAQ Driver Support for WindowsUsing the DAQ Assistant or Creating a DAQmx Task in LabVIEW 7.0 Evaluation VersionFrequently Asked Questions about the LabVIEW 7.0 Evaluation VersionZvezdana S.
