Can't write russian, japanese and other language on block diagram string
Before going to the nuts with a global rant....
I must display some text constant which depends on a language.
Languages are japanese, korean, turkish, polish, russian, and the main european languages.
Now, I thought to make a 2D string array, the colum index is the language, and each row is a message (there are only 11 rows).
I create this 2D string array constant on the block diagram, and then assign it to a indicator, so that I can retrieve it by local variable.
I have all the text already translated.
The problem is that I cannot copy paste the text in some language onto the block diagram (polish loose some signs, russian and japanese is "?????" everywhere).
Only some languages are OK (german, italian, english, I think turkish also).
So I kindly ask:
1) WHY
2) IT IS POSSIBLE SOMEHOW TO DEFINE THIS 2D array string constant with Unicode text in Labview? I have Labview 2009 sp1 and 2012 sp1.
thanks
(3,529 Views)
You need to enable it...
P.S.: play very carefully with Unicode enabled.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,525 Views)
