Can the Color Table property of Intensity Graphs accept > 256 colors?
Hello all,
I am trying to make use of the Intensity Graph, and would like to input a colortable with 4096 colors.
However, looking at the description in the help file for this property, it seems like the colortable accepts only 256 colors:
Color Table Property
Short Name: ColorTbl
Requires: Base Package
Class: IntensityGraph Properties
Array of 256 colors defining the color map.
You can set the color of the front panel object by wiring a hexadecimal number with the form RRGGBB or by wiring the color box constant to the property
Is there a workaround or an alternative solution for this?
Thanks alot,
Victor
(2,623 Views)
Use a picture indicator and a little bit of code. 🙂
(2,621 Views)
Hi altenbach,
Sorry to be revisiting this 2 months on... but would you be able to provide some pointers to guide me in the right direction? As I am still quite unsure of how to get started. 🙂
Victor
(2,573 Views)
