Can the Labview web server be run stand alone?
Can the web server run without having to run a particular VI or executable? Can I launch it as a service everytime I reboot for example?
Manu.
Certified LabVIEW Developer (CLD)
(2,995 Views)
Manu,
assuming you have a LV with build in web server you only have to enable the web server in Tools>>Options>>web server:configure. From then on you have a web server running which you can get documents from with URLs like http://localhost. Change localhost to the name or IP adress of the computer where LV is running on if you access it from a remote machine.
You cannot start LV as a service since a service is a special application which must provide a interface for the service manager. You can start LV each time when you put a shortcut into one of the autostart groups or into the registry under the "Run" key (use regedit to search for the correct location).
I think that if you will build an application and set the web server enabled (through the in
i file) you will have a web server and will be able to use LV for development on the same machine.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,995 Views)
