Can the mean be taken from an array of daq reads
I am trying to read in thermocouple readings. First, I used the Sample Channels block, but this was unwanted due to the daq clicking with each reading. Now, I am using a continuous reading, but I need to take the mean in order to reduce the effects of the noise on the readings. When I try to do this, I am denied. Any help is appreciated
(2,489 Views)
Hi ToddT -
What do you mean by denied? Does it not work?
If you are building these continuously read values into an array, the simplest way to take the mean is to use Add Array Elements found on the Numeric Functions Palette. Take this sum and divide it by the number of elements in the array (use the Array Size VI). I've attached a screenshot of how this method would work.
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(2,489 Views)
