Can the time/date text of a float indicator be displayed on a single line?
Very simple question: is it possible to get the time+date numeric text format for a float to display on a single line instead of time on top line and date on a 2nd line? I am frustrated trying to get parallel arrays of timestamps and data to line up on the front panel. I am handling potentially large data sets (30+MB), and don't want to have to convert all the timestamps to strings.
(2,845 Views)
Are you using LabVIEW 7.0? If so, you can set the format string to do that. Right-click on the control and select "Format and Precision". Select the "Advanced editing mode" radio button on the button and type the string "%<%X %x>T" into the Format string field at the top.
You can read more about the different format strings in the help.
(2,845 Views)
Nope, I'm using Labview 6.1.
(2,845 Views)
6.1 has only two formatting choices for time: absolute or relative. One thing you can do is format the strings yourself and use an array of strings instead.
(2,845 Views)
