Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can we control the queue processing speed in labview?
worker
Member
02-13-2004
12:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am trying to control the queue processing time using loop delays, but it always goes into infinite loop. pls help
thanks in advance
0
Kudos
Message
1
of 4
(3,163 Views)
Reply
Re: Can we control the queue processing speed in labview?
Ben
Knight of NI
02-13-2004
03:31 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Please post some code for us to look at.
That will let us help you,
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 4
(3,163 Views)
Reply
worker
Member
Author
02-29-2004
01:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello Ben
I am attaching the VI . It has UDP connections going to the queue and connecting after dequeue. I want to slow down the rate of dequeueing.
thank you
UDP_Sender_v2.vi 62 KB
0
Kudos
Message
3
of 4
(3,163 Views)
Reply
Ben
Knight of NI
02-29-2004
08:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
All of the code in your loop executes on each iteration of the loop. That includes your deque.
Use two loops. One for queing one for deque.
You should then be able to control the deque rate separately.
Ben
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
4
of 4
(3,163 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
