Can we convert a RGB image to monochromatic image in Vision Builder or assistant?
Can we change a RGB image to a monochromatic image in Vision Builder or assistant ?
Apart of extracting a single plane (R plane or G or B) ?
Thanks and Regards
Gaurav Pal
(2,608 Views)
I don't use Vision builder - so I may not really get your question, but if you'd like to perform operations on image data you already have you probably can - it all depends on what you are trying to achieve.
You could just add the RGB values, divide by three and coerce the Array back to U8.
A good idea to get started on this would be to search the forums for "picture control" - you'll see some interesting stuff 🙂
Regards Florian
(2,602 Views)
