Can we create a simulated DNet device with DAQMX?
I had no access to the Dnet interface today so I was thinking if there was a way to create simulated dnet devices on which I can run tests on. I did some searching and I found none. If you guys have any useful resources that would be really helpful. Thanks.
Labview Learner
(3,085 Views)
Ashaironix,
I did an internal search and couldn't find any documentation for such a setup; were you hoping to create a simulated device in MAX that could interact with DAQmx and LabVIEW?
Kirk L. | Applications Engineer | National Instruments
(3,046 Views)
Yes, I was looking for something that MAX can create ( a virtual Dnet Device) which later labview can easily detect anbd work on it.
Labview Learner
(3,043 Views)
Ashaironix,
I couldn't find any documentation or examples of MAX simulating any of our Dnet devices. Since our PCI-DNET devices have been end-of-life'd, I suspect that simulation of these devices cannot be done in MAX.
(3,028 Views)
