Can we design analog to digital signal conversion block diagram (ADC) in labview
hi every one,i've doubt i.e can we convert function generator output (i.e analog signals) to digital signal in labview......can anyone help me how to create ADC circuit that means ADC Block Diagram in LABVIEW.....please give me solutions for my problem
(4,095 Views)
Hi guru,
everything in a computer program is already digital.
Where does your "analog" comes into play?
(4,086 Views)
kkkkkkkkk. can we design DAC ?????
(4,077 Views)
hello ur mistake from function gen we get analog signals and they are not in digital form (1 and 0's form) so im ask for conversion of ADC ckt in labview
(4,064 Views)
Hi guru,
from signal generation VIs you get arrays containing float values (aka DBL). Those floats are just digital values made of 0s and 1s…
Any value in your computer is digital!
To provide a solution you need to rephrase your question! What exactly do you expect as result of your operation?
Edit: kkkkkkk ur ckt ???
(4,045 Views)
This is just one of several questions of his related to a signal generator and all of them are very ambiguous. O understand the difficulty in posting questions here when English is not your native language but you must attempt to clarify what you are actually trying to do.
(4,029 Views)
