Can we handle multipil slaves at a time ( using modbus protocol ) with labview
How to code this program in a simple way
(2,522 Views)
Have you looked at the MODBUS library in LabVIEW?  See below.  One of the cluster input will allow you to change the slave id for multiple slaves.
http://zone.ni.com/devzone/cda/epd/p/id/4756
Kudos and Accepted as Solution are welcome!
(2,493 Views)
