Can we run another exectuiable program in LabView
Such like running a hello.exe(written in c) in the LabView?
(2,764 Views)
Yes,
The basic item is found in the Functions Palette under Communication. It is called System Exec.vi.
If you write the C code, it may be better to create a dll instead and call the function directly using a "Call Library Function Node", which is located under "Advanced".
-JLV-
(2,764 Views)
