Can we run two while loops independently in one application?
I am acquiring two channels using PCI-6052.both channels to be read at 2ks/s,but I want to scans read at a time different for each channel,So I put two AI-read vi's in two different while loops.but the second while loop waits until the first is completed.Can we run independently both while loops?
(2,721 Views)
Not possible
(2,721 Views)
You could sample both channels at higher rate (4K/s), then downsample for each channel.
-Joe
(2,721 Views)
I'm not familiar with the PCI-6502 but it sounds as though what you might want to do is have a third loop that performs the acquisition from both channels and passes data out to the first and second loops using queues or some other method....
(2,721 Views)
