Can we use HC-SR04 Ultrasonic sensor only with myDAQ ?
Actually i wanted to use HC-SR04 Ultrasonic Sensor using myDAQ alone without any arduino board, with myDAQ i need to provide TRIGGER and using DAQ assist i have to analyze the magnitude and signal obtained from ECHO,
Can i get suggestions or help in making that possible in LabVIEW?
Message 1 of 1
(2,955 Views)
