Can we use RS422 serial port communication in LabView.???
Thank you so much Now its working but
if I enter "123" in write buffer why it is executed continously like 123 123123 123.......... and even if i click on stop button it won't stop
Message 21 of 48
(3,563 Views)
Accepted by topic author arun2929
Hi arun,
Because you send the "write buffer" in each iteration!?
Read the manual of your device. It should contain all details of the communication protocol!
Message 22 of 48
(3,559 Views)
Yeah.  Back in message 6 I told him there was no com port saved as default in the VISA control.
Message 23 of 48
(3,550 Views)
May be at that time i am unable to get what you told me ,
Thank you
Message 24 of 48
(3,546 Views)
It's important that if you don't understand something, reply back asking what we mean.
I'm glad you've got it working for you now.
Message 25 of 48
(3,539 Views)
@arun2929 wrote:
Hi Gredw
I know I am annoying you , But i  am aBeginner ... I get same error even i create any VI on serial port please check the following attachment , i find that example in our forum even i execute that example i get the same problem
can you please edit that VI or suggest me any of your example for communicating over serial port
Thank you
Hello arun2929,
Don't fret over annoying people with your questions.  It's very difficult, almost impossible, to become Knight of NI without being annoyed at beginners.  I try to help out on forums where I can and of course, I am nowhere near the knowledge level of these guys.  But even for me, I find myself getting annoyed at some of the questions being asked, even though I was in your beginner's shoes not too many years ago.  My advice?
  • Be thorough in explaining your question.  I have literally seen questions that say "My VI that is supposed to do this and that, doesn't work.  Can anybody tell me what is wrong?"  No pictures, no code, nothing.
  • Provide code.  Not a picture of your code, unless it is a snippet.  If you don't know what a snippet is, look it up.  They are great for showing code on the forum, as well as sharing code to those who wish to run it from their computer.
  • Read all of the responses in the post.  No one likes to help someone who isn't going to read the advice they are given.
  • Give kudoes and mark a solution.  Solutions make it easy for people with the same problem to easily find the solution that helped you.  Kudoes are a way to give credit to those who help you and whose advice you found useful, event though it may not be the solution.  As a contributor to the forum, I enjoy trying to get my name on the Top Kudoed Authors page and I can only imagine that others enjoy it too.
aputman
Message 26 of 48
(3,513 Views)
Thank you @aputman
I have few more doubts which is continuation  to this Topic, can i ask here or else craete a separate discussion .??
Message 27 of 48
(3,506 Views)
Hi arun,
When it is related to the topic "serial communication with LabVIEW" you can stay in this thread.
When it is a different problem: create a new thread.
Message 28 of 48
(3,499 Views)
I have 2 doubts
1) please check the following attachment while executing that VI we have an error regarding session time mentioned in the screen shot
2) can we send text files over serial port ?? if yes how ..?
Thank you
Message 29 of 48
(3,496 Views)
Hi arun,
1. The device didn't answer to your request before the timeout…
In your VI you disabled the TermChar and try to read 31 bytes from your device.
Do you expect exactly 31 bytes (or more) as answer?
Does your device use a TermChar? If yes: why did you disable the TermChar?
2. You can send any string you like using the serial port. Infact the VISAWrite function uses a string as input!
Keep in mind: serial communication was never ment to transfer "files"! It was use to transfer commands and data clearly - both limited to reasonable length/datasize! So you might transfer your "text file" part by part…
(What kind of device are you using so you even want to transfer "text files"?)
Message 30 of 48
(3,492 Views)
