Can we use Windows API functions
Hi to All
I am trying to programmatically from LV to click a "next" button on a "window" on my screen comming from another application that I am running then filling out some lines that otherwise I would had manually typed. Can I do all of this using windows API set and from LV??
Thank You in Advance
(3,607 Views)
The general answer to your question is "yes". If you do a search for "SendInput" or "SendMessage" you will come across samples that do that.
(3,597 Views)
Hey Togos,
Developer's Zone:  Windows API Function Utilities (32-bit) for LabVIEW
Brian B
Account Manager
(3,574 Views)
