Can we use myRIO/any NI RT device as Client in TCP/IP Communication
Hello every one,
I am trying to use my PC as TCP/IP Server and NI myRIO as TCP/IP Client. when i run the VIs I am getting error in both VIs they are not communicating. i had referred my examples on myRIO with TCP/IP and i had found that they are using myRIO as TCP/IP Server. i have a doubt that can we use myRIO/any NI RT System as TCP/IP Client. if possibility is there please let me know the resources.
Thanks in advance.
(2,305 Views)
Of course! Just use TCP Open to initiate a connection to the server from your device! You need to know the address of the server and the accordingTCP/IP port number on which your server is listening.
Rolf Kalbermatter  My Blog
(2,263 Views)
(2,218 Views)
