Can you add a Horiziontal Bar to a Chart?
Basically I have 2 analog inputs being read and displayed on a 2 independant charts.  The user is prompted to input tolerances that are then used to figure out a maximum and minimum value.  If either of the input values do not fall within the min/max value an alarm occurs and turns on a red LED on the front panel.  The chart is then saved to file that can be reopened for review.  The charts clear and await a new analog input.
What has been requested of me is to add horizontal lines to the chart that will display the min/max values so that the user can easily identify where the failing value occured.  I have to do this without altering the information on the 2 existing charts?
Is there a way to overlay another transparent chart on with the same scale and just draw the min and max lines?  Is there a simple solution I have overlooked (only been using labview for 2 weeks)?  Any suggestions/ideas would be very helpful.
Ken
(2,782 Views)
The Max and Min lines can be plotted on the chart with the data. This does not alter the data, it just changes the display ! You need to build an 1D array of data/max/min, then to make this array a 2D array, before passing it to the chart. See the attached vi.
Chilly Charly    (aka CC)
(2,776 Views)
Thanks alot.  That was exactly what I was looking for.  I figured it would be something simple that I was overlooking.
Thanks again,
Ken
(2,754 Views)
