Can you call an express VI interface when running LabVIEW code
I want to use an Express VI edit interface, in my program, so that I don't have to recreate the interface. Is it possible to call that VI to show its front panel in Express VI mode
(3,132 Views)
ADL,
Is there a specific express VI that you want to call? Once you open an express VI front panel, it is not an express VI any more. You can then save it as any other VI and call it as a subVI or dynamically.
Zvezdana S.
(3,132 Views)
Yes but once you convert to a real vi, they look nothing like the express VI interface. I actually want to use the "Configure Mask and Limit" functinality inside of my code. If I convert it to a VI, then the interface has completely changed, and I need to recreate the Vi to get a interface that is similiar to the Mask and Limit Express VI configuration screen.
(3,132 Views)
