Can you continuously read digital inputs on NI9425?
See attached errors/tasks.
Message 11 of 15
(1,287 Views)
I'm thinking it is an issue with the way the waveform is being built.  You really don't have a digital waveform, but a series of 5 individual true/false data points.  You might want to look at N channel 1 sample.
Message 12 of 15
(1,283 Views)
The problem with having only one channel is that the data from boolean controls being sent to the digital out DAQ won't continuously be updated. If I choose 1 sample, then it'll only execute the one set? This ties back to my original problem.
Message 13 of 15
(1,265 Views)
Accepted by topic author sam18
Right now nothing updates because you build up a queue of 5 items as soon as your VI starts based on the setting of your controls when your VI starts.  There is no way to change those controls until you stop and restart your VI.
I think you are misunderstanding the concept of dataflow.  I recommend you go through the
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
Also take a step back.  Make a simple VI, base it on some digital output examples in the Example Finder and prove that you can get that to work for you.  Only then start adding the digital input.  (Create a separate example VI to test that first.)  I don't know what your goal is with the queue in there.
Message 14 of 15
(1,251 Views)
Thanks! I was overly complicated/convoluting the problem. It was extremely simple all along. I just played with the read/write modules and it worked.
Message 15 of 15
(1,231 Views)
