Can you control Boolean outputs with a timer?
Is it possible to control a constant Boolean output with a timer. For example having a "constant true" being outputted after X amount of seconds/milliseconds? I want to have a while loop containing a continuously running DAQ assistant, until the timer controlled "constant true" value is outputted to the termination button after those X seconds/milliseconds.
Thanks for any help.
(3,679 Views)
Everything is possible!
There's the "elapsed time express VI".
What is a "termination button"?
Can you show us some code?
(3,661 Views)
Apologies, I meant the red "loop condition" button found in the lower right of loops. I have a state machine attached with a continuous sine function generator, I want to run the first state with this sine generator for a number of seconds before switching to the second state and ending the program.
(3,650 Views)
