03-20-2006 03:00 PM
03-21-2006 01:37 PM
Dave,
The DIO lines on any DAQ device that uses the DAQ-STC ASIC can be configured on a per line basis, so using PFI and DIO lines on the same port will work just fine.
You can run a quick test on this using the "Gen Dig Pulse.vi" example (found in the NI Example Finder under Browse -> Hardware Input and Output -> DAQmx -> Generate Digital Pulses). You should be able to generate a pulse on one of the PFI lines on the board, then read that pulse back in on one of the DIO lines of that port using an external connection.
-Justin
