Can you give me an example using the vi, interpolate 1d array.vi
Hi
I am having trouble using interpolate 1d array. Is it possible for you to give me an example of how it is used?
Thank you.
(10,344 Views)
Not sure about what you are looking for.
Let us assume that you have an array containing Y values 1, 2, 5, 10, 17, 26.
The basic idea is that there is a continuous (but unknown) relationship between the index values, and the corresponding table values.
So, what would be the Y value corresponding to i = 2.5 ?
Or, what would be the i value corresponding to Y = 3 ?
That's were the interpolating tools come to the scene :
With the "Interpolate array" function, you pass the fractionnal i value, and you get the Y value, calculated from a LINEAR interpolation between the table points. Here, for i = 2.5, the Y value is half-way between 5 and 10 = 7.5. Remember that this is a linear approximation. In this example, the unknown function was obviously Y = i^2 + 1. So, for i = 2.5, the true solution was 7.25. Not far from the linear interpolation, but not equal either.
With the "Treshold 1D array" function, you pass the Y value and you get the corresponding i fractionnal index. Y = 3 is 1/3 between Y = 2 and Y = 5, so i = 1.3333... The validity is the same : linear approximation (what was the true solution here ?). Beware, this function works only with Y values arranged in ascending order.
There are other interpolating vis in the "Mathematics" subpalette, which use more elaborate strategies.
Hope this helps...
CC
Chilly Charly    (aka CC)
(10,324 Views)
TUDS;
Check the following example: Threshold 1D Array Example.
You can search the example library for interpolation and similar terms.
Regards;
Enrique
www.vartortech.com
(10,280 Views)
