Can you install a LabVIEW executable on Bart PE or Windows PE?
(3,035 Views)
Hi sammamish...,
it should be possible if you install the runtime engine, while creating the Part PE partition. Do you need some hardware?
Mike
(3,029 Views)
I should have provided more information at the outset. I would like to use a USB thumbdrive to boot an OS and run the LabVIEW executable from the USB drive. I have tried to install the LV 8.5 runtime engine. At the beginning of the install a popup window comes up with "Microsoft Visual C++ Runtime Library, Runtime Error!"
I'm trying to locate someone who has attempted this whether successful or unsuccessful.
Thank you.
(3,021 Views)
