Can you output multiple digital voltages at once using DAQ assistant?
I am trying to build a labview code that lets me output an identical analog voltage from 4 unique digital outputs on a NI DAQPad-6259. I wanted to use 4 separate DAQ assistant VIs for each voltage output channel, but while running more than one of the assistants, the program cancels with the error message:
"NI Platform Services: The specified resource is reserved. The operation could not be completed as specified."
I was curious to how to fix this issue, and if this is just a DAQ assistant VI problem or a device problem. I did wire each DAQ VI to a unique analog output channel.
I have attached the code below, I am new to LabVIEW and this is my first time working with a DAQ.
(3,402 Views)
Accepted by topic author Ramonk
I did not open your VI, but my advice is to completely forget using DAQ Assistant Express VIs. Start to use the proper "low level" DAQmx functions: https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
(3,386 Views)
Yes you can.  You just need to add the additional channels to a single instance of the DAQ Assistant.  Merge the different voltages together.
But I would also recommend learning how to use the lower DAQmx functions.  You will use N Channels, and either 1 or N samples versions of the DAQmx Write.
(3,381 Views)
