Can you programmatically change a picture control frame/border
In a platform neutral manner can I programmatically change a picture control frame/border
Message 1 of 28
(5,285 Views)
If you use the picture from the classic pallette you can paint the border transparent. Is that of use?
Ben
Message 2 of 28
(5,275 Views)
What I mean is during runtime.
Message 3 of 28
(5,270 Views)
And you can do away with the border alltogether by setting the resizeable window selection to unchecked.  (the border is to grab for resizing...if you don't want to resize it, the border goes away.)
Hummer1
Always changing size
Message 4 of 28
(5,269 Views)
Please define "change" so we don't waste our time guessaing at what you need.
Ben
Message 5 of 28
(5,259 Views)
What I want is to alter the color or visability while the VI is running.
Message 6 of 28
(5,256 Views)
You can make it look that way using many differnt methods.
The simplest is to make the border transparent and put a boolean behind the picture. Size the boolean so it looks like it is the border of the picture. Change the color of the boolean and you are on you way.
Ben
Message 7 of 28
(5,251 Views)
Assume I have a Vi that has a Picture Control.
I run the VI. I currently alter the size, content, and location
under program control. I just want to change the border color
from red to green, programmatically.
Message 8 of 28
(5,247 Views)
Resize and reposition both.
Ben
Message 9 of 28
(5,241 Views)
Altho this is a bit of a kludge, it might work. I cant find a Boolean control that it selt
does not have it's own border.
Message 10 of 28
(5,222 Views)
