Can you programmatically change the width of columns in a table control\indicator
Is it possible to programmatically change the width of columns in a table control\indicator ie to fit to width of the data or in my case the header information.
(2,877 Views)
Create a property node (or reference) and use the 'Active Cell' property to select which column you want to change and then use the 'Cell size'--> 'Width' property to change the size.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,877 Views)
