Can you send me the schematics to the CB/SCB-2162 board (ASSY188290C-02)?
I am using the PXI-6552 Digital I/O and SCB-2162 board. Do you have available the schematics to the CB/SCB-2162 connector block. I need the schematics so that I will know what to components to install in the CB.
Also, where do the DIO grounds on the CB-2162 terminate? Do those ground have a corresponding ground pin on the PXI-6552?
(4,275 Views)
Will the manual suffice?
http://www.ni.com/pdf/manuals/370369d.pdf
-AK2DM
(4,268 Views)
User Guide isn't as go as a schematic. Need a schematic or else I will send too much time trying to figure out where things are going
(3,889 Views)
My world is on its 4th circle around the Sun since the time of previous post on that thread! Smiley Surprised
-DP
(All connector pinouts are available in the manual and also labelled on the board, I can't tell what would be the point of still needing a schematic when everything is right on the board - it's a simple signal breakout board with additional prototyping area!)
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
(3,882 Views)
