Can you tell me please which drivers should I install? Are they on one of the Lab View diskets?
Countinue our writing...
I realy need to run this EXE file on Win2000 without sometimes problems of no response.
Thank you
(2,638 Views)
It depends on your LV' version.
You can download the latest version of the run-time engine too.
Also, try to have the latest drivers and service packs.
(2,638 Views)
I would also suggest you download and use our latest drivers from our website, www.ni.com, both in the devlopement environment and the application environment. The drivers that are necessary in the application environment depend on the functionality being used in your executable. You will at least need the LabVIEW Run Time Engine on the target computer. If you are using GPIB, you will need NI-488.2, if you are using DAQ, you will need NI-DAQ, etc.
Ryan Tamblin
(2,638 Views)
