CanOpen with IXXAT - Sync-ID
currently I'm working with CANopen and for this I'm using the converter and VIs from IXXAT/HMS.
Till now we use the standard configuration, especially the sync-ID 0x80, so we had no issues.
But now we are using another sync-ID and so we have to change it. But I realized that there is no possibility.
Does anybody have an idea or had the same issue in the past?
Best regards
Stefan
(1,987 Views)
Hi Stefan,
@Stefan_shs wrote:
currently I'm working with OpenCAN and for this I'm using the converter and VIs from IXXAT/HMS.
In CANopen there is only one SYNC message.
So there is no issue as you cannot change the SYNC message to any other ArbID…
(1,980 Views)
