CanOpen with IXXAT USB-to-CAN
Good afternoon,
I'm trying to make the CanOpen communication protocol between IXXAT - USB-to-CAN device and labview. So, I'm having problems defining the master / slave nodes, NMT, SDO, PDO, ... Does anyone know how to define this in a simple way in labview?
I have seen that people use the following library: https://www.ni.com/docs/en-US/bundle/ni-industrial-communications-canopen/page/canopenhelp/canopen_h..., but is this library generic? Can I use it with IXXAT USB-to-CAN?
Is there any other way? Does anyone have an example?
Thank you very much for your help,
Iñaki
(5,999 Views)
I believe the NI CAN Open library only works with NI series 2 (old) devices. I've had my eye on
https://www.ni.com/en/support/downloads/tools-network/download.clampon-can-monitor.html
this add-on but haven't had a chance to try it out yet.
(5,985 Views)
Accepted by topic author iiribarbilbao
Hi
This will not work
you will have to download VCI driver from the IXXAT homepage.
Maybe they have there a LabView Library for CanOpen.
Or you should do a call to them and ask for support
If not you have to do it in LabView by using the LabView CVI driver
Regards
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,965 Views)
