Cancel one button dialog
In one step of my application, one button dialog pops up to ask test operator to push a button. After the button push, the test operator needs to click OK button then the program will continue.
I'm wondering whether there's a way to cancel the dialog after the program detect the button is pushed? Any suggestion is welcome.
(2,801 Views)
Instead of the LabVIEW one button dialog, write your own vi that pops up as a dialog box (set that using File ->VI Properties -> Window Appearance) and then you can use whatever conditions you like for deciding when to exit.
Richard
(2,796 Views)
Thank you for the response. This is what I have been thinking, to make a subvi to handle this kind of situation.
(2,792 Views)
