Cannot Save or open anything
i cannot save or open anything in my LabVEW projekt. It stuck me as I want save a new created SubVI. I use LabVIEW 14.0.1.
When I push File\Save or File\Open a messagebox opens for a fraction of a second.
Does anybody know a solution to the probem?
Best regards
Andreas
Message 1 of 14
(4,303 Views)
Has it worked previously? Have you changed your system in any ways? Do you have an evaluation version or a full version?
Message 2 of 14
(4,258 Views)
Yes, it worked previously. I didn't changed anything on my system. I work with a full version.
As i started to work with LabVIEW it worked normaly. Then I programmed circa four houers with LabVIEW and then I try to open something. But it hasn't worked out. I try to save my project but it hasn't worked out. The only way I saw is to close LabVIEW. Than I restarted it and it works normally. But my last changes in my code was lost.
Do you have any idea what the reason could be for my problem?
Message 3 of 14
(4,242 Views)
Where is your project/VI saved on your computer? Do you have permissions to create or edit other files in that folder?
This is unexpected behaviour, but there is a simple workaround. Should this happen again, try copying your entire code to blank VI, you should be able to save then.
Message 4 of 14
(4,220 Views)
My Projekt is save in an folder directly on c. I have admin permissions on my computer. Also on the folder of my project.
Thank you for your suggestion, but i tried it. Unfortunately was that not a solution. The new blank VI also could not save himself.
Yesterday, I had the problem again.
Message 5 of 14
(4,196 Views)
Not knowing more of your system, the best idea is probably to reinstall the program.  :~\
Message 6 of 14
(4,141 Views)
Message 7 of 14
(4,127 Views)
Check your keyboard?  Maybe the return key is stuck every so often?  Just a wild guess because you said the dialog goes away as soon as it comes up.
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(4,122 Views)
This is actually a good suggestion.  I had a strange case where I couldn't right click any objects.  I tried right clicking on a front panel control to get to its properties but the tools palette came up.  I then left click and multiple objects were selected.  Turns out my keyboard went into some crazy mode where the shift key needed to be pressed once to enable and pressed again to disable, instead of being held.  I unplugged the keyboard and plugged it back in and it went back to normal.  If the enter key is being held down with software or hardware, strange things could happen.
Message 9 of 14
(4,105 Views)
Yeah, keyboard going crazy has happened to me too. Typically shift or alt.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 14
(4,092 Views)
