Cannot create an .exe in LV2023Q1, but same project in LV2020 does build successfully
In LABView 2023Q1 I have a project for which I want to create a .exe. The build process fails with an Object reference is invalid error; see attached. If I back save this project toLV 2020, the build works.  I have uploaded the error message and a zip with the project that fails. Go into the PennTrapPot, open the project, and then try the one build in the project.
Any advice welcome.  This is part of a very large project (about 3000 VIs) and an attempt to backsave the entire project to LV2020 failed. It is possible that I could get the backsave to work eventually, but just retreating to 2020 would not not be easy.
This is on a fairly fast W10 machine with ample memory and disk space.
(1,247 Views)
Accepted by topic author Joel
According to NI support, this is a known issue in LV2023Q1 and will be fixed in LV2023Q3.  "The current workaround is to replace your 'VISL_findDependentVISvr.vi' "  This fix worked for me, and I have attached the file that NI provided.
(1,189 Views)
This is where the patched version of the VI should be copied:
 [LabVIEW 20xx]\vi.lib\lvdsc\servers\visl\redist
(1,178 Views)
