Cannot create control for Imaq image.ctl
Accepted by topic author SeanJ
Hi, SeanJ
 I hope this will help you surely. Please find the attached Zip file.
Hope it helps,
Dhans 😉
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
Message 11 of 14
(1,975 Views)
Hi Dhans,
Many thanks.  Ctrl Refnum!  I just couldn't think outside the box I put myself in.  Arrgh!
Much appreciated.
Seán
Message 12 of 14
(1,943 Views)
Always welcome !!!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 13 of 14
(1,938 Views)
Dhans,
How did you create the Ctl Refnum in "Untitled 8 (SubVI).vi"?  I am having the same problem as the OP.  I want to be able to pass a reference to an IMAQ image control from a caller VI into a subVI.  See my modified version of your example code for the reason why.  Right-clicking on an IMAQ image control to create a reference, then right-clicking on the reference and choosing "Create Control" does not create a refnum control.  It does nothing.  Also, LabVIEW will not allow me to create a subVI of a selected portion of code by using Edit->Create SubVI if the reference to the IMAQ image control is passed into the portion of code I want to create the subVI from.  I'm using LV 2019, but have down-compiled the attached example into LV 2014.
Scott
Message 14 of 14
(1,171 Views)
