Cannot disable Windows Explorer for LLB files
I cannot disable the option to use Windows Explorer for LLB files.
Labview Version 8.2.1
Windows XP PRO Ver 2002 SP2
When I uncheck the box, then restart the computer, the option is still enabled.
In fact, when I uncheck the box, then go back to Options / Enviroment, the box is checked again.
Reinstalling LV had no effect on this behavior.
Any suggestions?
Tim
Message 1 of 9
(4,467 Views)
There are a few things to check:
Do you have write access to LV's ini file? I can't imagine how you would not, but it's a possibility.
After you change the setting do you shutdown LV before restarting the computer?
What is the effect if you manually put the following line into the LV ini file?
enableShellExtension=False
Mike...
Message Edited by mikeporter on 06-12-2007 10:51 AM
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,455 Views)
Mike,
Thanks for the suggestions, but nothing worked.  I recently installed on another computer and found identical behavior.  The most curious thing I see is that the check box does not remain unchecked when I return to the Options > Environment page.
I'm moving away from llb's these days anyway.
Tim
Message 3 of 9
(4,413 Views)
Hi Tim,
This issue has been reproduced and was reported to R&D (# CAR ID 48H9DL2B) for further investigation. Thanks for the feedback!
Elizabeth S.
Message 4 of 9
(4,380 Views)
So what causes it? Installation problem? Setups Incorrect? Phase of the moon?
If it starts happening is there a workaround to stop it?
Mike...
LabVIEW Champion
Message 5 of 9
(4,372 Views)
Hi Mike,
This is a known issue with LabVIEW 8.2.1 and there is no work around at this time.  A Corrective Action Request (CAR) has been submitted and R&D is investigating the issue.
Elizabeth S.
Message 6 of 9
(4,354 Views)
So the big question is that I have V8.2.1 installed right now on my laptop and am not seeing the problem. The people I'm contracting with are wanting to upgrade a bunch of systems. Was I just lucky or are there situations that trigger the problem? Also will this be in a free bug fix, or will we have to pay to get this bug fixed?
Mike...
LabVIEW Champion
Message 7 of 9
(4,345 Views)
Very nice, Mike. You're the ninth person to cross the 2000 posts limit. I started a well deserved congratulations thread in the BreakPoint (I link to it since you never post there, so I wasn't sure you know about it).
___________________
Try to take over the world!
Message 8 of 9
(4,335 Views)
Hi Mike,
I have tested the selection on a couple of machines here and was able to reproduce the same problem that Tim was encountering.  There is no documentation on a trigger for this behavior.
Did you restart your computer and find that the option was still unchecked?  We may just consider you lucky!
I do not have specific information for a fix, but the issue has been reported to R&D for further investigation.
Elizabeth S.
Message 9 of 9
(4,310 Views)
