Cannot find Agilent N9310A driver once it is installed.
The driver is installed.
It is identified under "Installed instrument drivers" in the "Find instrument drivers" page.
Using a mouse right click and then -> Input -> Instr Drivers. In the Instrument Drivers window, the N9310 driver is not listed.
Is there another way to select this driver?
(2,743 Views)
Have you restarted LabVIEW since you installed the driver? If that does not work, you should be able to add the driver to your palett manually. Go to Tools>Advanced>Edit Palette Set. Open the Instrument I/O>Instrument Driver palette, right click and select Insert>Subpalette>Link to a plaette in a project library (assuming you are using the project-style driver) and browse to the lvlib. Save changes and you should be all set.
(2,734 Views)
Restarting LabVIEW did not help but adding the driver manualy did the trick.
(2,727 Views)
