Cannot find ExcelExamples.llb in LV2013
Hello all!
I have an old VI that I'm trying to open. I am missing the "LabVIEW 2013/Examples/comm" folder and the file ExcelExamples.llb that should reside there.
My questions are;
Do I have to load a toolkit to get this file and which toolkit do I need?
Did this file come standard in older ver of LV?  ( I used to have the file but I don't remember loading a toolkit)
Thanks for addressing this boring question.
Rob
(4,190 Views)
Accepted by topic author V-Rob
Those examples were removed in LabVIEW 2013 and later. The comparable examples are now located here:
[LabVIEW 2013 and later]\examples\Connectivity\Excel
If you can't find what you need in there, I've attached the ExcelExamples.llb from LabVIEW 2012 to this reply.
Also, as a general rule, your code probably shouldn't link to stuff in the 'examples' folder. Make (renamed) copies of whatever you need from there and distribute the copy with your code.
(4,175 Views)
