Cannot find Ivi_InitWithOptionsAndGetError in ivi.dll for Keithley 6487
Hi Guys!
I'm trying to to some programming on the Keithley 6487. I thought it would be easy to just download the drivers on their webpage.
So i downloaded the the drivers and converted them with LV Interface Generator for Labwindows/CVI instrument driver 1.2.
Unfortunately the drivers to not work because of several problems: Sometimes the above mentioned message appears.
Another Problem is that the Intrument handler do not show my instrument. Usually i use VISA session to program, but this instrument handler seem to be IVI type sessions. How can i change this stuff, or how does it recognoize my Keithley?
Another questions is: I've seen something called Keithley I/O layer on keithley homepage, and it seems that the driver required this stuff. Can somebody explain to me what this I/O layer is?
Thank you very much in advance, looking forward to hear from you
Andreas
(3,023 Views)
Hello Andreas!
I don't know the Keithley 6487 but If you look at the Keithley websites there you can read that the Instrument Driver "Requires Installation of Keithley I/O Layer (KIOL-850)".
http://www.keithley.de/products/locurrhiresist/?path=6487/Downloads
Did you installed this I/O Layer?
The Keithley I/O layer software manages the communications between Keithley instrument drivers and software applications and the instrument itself.  The I/O layer handles differences in communications required to support GPIB, serial, Ethernet, and other communications busses so that drivers and software applications do not need to handle the differences themselves.
More Information you get here:
http://www.keithley.de/com/data?asset=50493
Keithley I/O layer download:
http://www.keithley.de/com/data?asset=50494
WolfgangZ
(2,996 Views)
