Cannot find Network-shared variable via web
I can't seem to connect to my vi.
The web server manager works and I see everything there, I just cannot seem to be able to setup something like Data Dashboard
(3,054 Views)
Hi Murph,
So could you deploy the shared variables? The problem appeared in the Data Dashboard part of your implementation? If so, can you be more specific, if it gives you an error, some text or aditional info?
Have you tried this document?
Getting Started with the Data Dashboard fot LabVIEW:
http://www.ni.com/white-paper/13757/en/
If you have a particular error, i would appreciate if you send me a picture, error code or any info for more detail.
Thanks in advance!
NavasMonk
National Instruments, México
ELP Support Engineer
www.ni.com/soporte
(3,022 Views)
I'm close but can't seem to see my shared-variables accross the web.
I've attached my proj and an image of what I see in the Web manager.
(3,013 Views)
Hi Murph,
The following KnowledgeBase articles provide some general troubleshooting steps for using network-shared variables, that may be useful.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6vdSAC&l=en-US
http://digital.ni.com/public.nsf/allkb/40D06E4EFB6B8B6B862572D10006FEB9?OpenDocument
Also, I cannot open the project file you attached. Can you attach a .zip file that includes all of the project files and VIs?
Best,
Catherine B.
(2,981 Views)
