Cannot find "Create new: Polymorphic VI"
I am completing the self-paced LabVIEW Basics II course.  I'm trying to complete "Exercise A-1  Sort Poly Array VI".  When I open the New dialog, in the "Create new:" I do not have a Polymorphic option under "Other Document Types".  All I have are: "Global Variable", "Custom Control", "Run-Time Menu", "VI Template", "Global Variable Template", "Control Template".  I've re-checked several times, just can't find it.  I'm using LabVIEW 7.1 Full.  Could it be an installation issue?
Certified LabVIEW Developer
NI-VLM Administrator
(3,131 Views)
Just do a New from LabVIEW (Not New VI) and select from the list under Other Document Types, Select Polymorphic.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,127 Views)
Sorry, you need the Professional Version
See Link: https://www.ni.com/en/shop/labview/select-edition.html
Message Edited by mfitzsimons on 12-01-2005 03:19 PM
Matthew Fitzsimons
(3,124 Views)
It's just not there.
(3,118 Views)
Thanks, I was wondering, the other exercises (like building executables) that required Professional pointed that out.  Oh well.  I don't actually need to build one for anything, just preparing for certification.
(3,117 Views)
Good luck with your certification.  I recently took and passed the CLAD.  I can't give you any hints but study everything they list on the CLAD prep.  The test was actually harder than I expected and I have been doing this for years.
Matt
Matthew Fitzsimons
(3,108 Views)
