Cannot find the labview runtime when creating installer
I'm trying to create an installer and to add the labview 8.2.1 runtime.  When I build  the installer,  a window pop and ask me to find where the runtime is located.
I have the runtime installed on my computer,  but it doesn't seem to find it.  What can I do to solve this problem?
Thnak you in advance
(3,929 Views)
Your images don't appear to have uploaded correctly, could you include an attachment of them in a zip file for me and I can look into this further for you,
All the best,
(3,923 Views)
Here they are.
Thank you,
(3,914 Views)
Hw did you install the run-time portion. It looks like you just downloaded the item into your area and did not initiate an install. It look like you are missing the .id file that is needed to locate the files.
(3,901 Views)
As you can see, I got it installed on my computer and you can see that I have the nidist.id in my folder.  I've tried to reinstall it and I get a message the say that it's already installed.
(3,895 Views)
When it comes up and Locate distribution, click on browse and point it to the Labview run-time.directory. It should install without a problem.
The problem is that you have not "correctly" install the libraries. I do not know about 8.5, but the "instructions" to do the installation does not create a "correct" installation. Generally, I load the driver disk on the disk and whenever the installation request the driver disk, I use that location instead.
(3,883 Views)
