Cannot get Windows Send To function to work with LabVIEW
Hi!
I'm trying to get the Windows Send To function (from right click on file) to work with LabVIEW, but I seems it won't work.
I've added ashortcut to LabVIEW in the Sent To folder, and it shows when i right click on a file, but nothing happens when i choose Send To -> LabVIEW.
The reason for wanting to do this is that our version control program (Rational ClearCase) is not set up to be able to recognize and compare *.vi files, so right click and Send To in the version tree would be very helpful for seeing old versions.
Thanks.
//Martin
(3,119 Views)
Wow. I was surprised to duplicate this behavior as well. Very surprising.
At any rate there is a simple enough work around. I made a batch file and then put a link to the batch file in the SENDTO folder.
Contents of my LV.bat (don't even need the echo off either if you don't want)
@echo off
"c:\program files\national instruments\labview 7.0\labview.exe" %1
Just make sure the path you use is the path to your actual labview executable.
This pops up a dos box very briefly but it works.
(3,119 Views)
