Cannot get column names from LabVIEW SQL statement
Has anyone worked with LabVIEW SQL from Hans-Petter Halvorsen. I have used it to get column names from a table. So I used the SQL query
SELECT COLUMN_NAME FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = 'Kokam_List' ORDER BY ORDINAL_POSITION;
and give it to the SQL select function and run it. And I don't get any error. But the output I am getting is an empty array. But I run the same code on SQL server management studio, then it does work properly and I get all the column names. Does anyone know why is this. Thank you.
Message 1 of 10
(5,202 Views)
Stack overflow suggests
select *
from INFORMATION_SCHEMA.COLUMNS
where TABLE_NAME='tableName'
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(5,182 Views)
No, that doesnt work either. I also used EXEC sp_columns 'Kokam_List' but doesnt work. EXEC sp_columns 'Kokam_List' also works in SQL server management studio but not in LabVIEW.
Message 3 of 10
(5,179 Views)
My first thought was that it was a difference in bitness between LabVIEW and SSMS, but you didn't get an error.  My second thought is to try double-quotes instead of single, i.e. "Kokam_List" instead of 'Kokam_List'.  I'm not super confident that this will make the difference, but I've seen weirder things before.
Jim
Message 4 of 10
(5,155 Views)
Nope, double quotes is giving an error.
Message 5 of 10
(5,150 Views)
I solved the issue. The issue was in the ODBC connection. When I created the ODBC connection one of the settings was wrong. So there is a connection and because of that no error but executing sql query is not possible.
Message 6 of 10
(5,089 Views)
Which setting was wrong ?
I would be glad to know (and surely others) if it happens to anybody else.
Message 7 of 10
(5,082 Views)
Well its the most important setting. Change the default database to. I forgot to change it to the database which I want. So the labview was just connecting to a master database in the system instead of the database I want which was really foolish.
Message 8 of 10
(5,069 Views)
I would consider this the second most important setting. The actually most important one would be the server address, port, and protocol if any. 😁
Rolf Kalbermatter  My Blog
Message 9 of 10
(5,051 Views)
It's so humbling to share stuff like this.  Thank you for sharing your solution with us.  🙂
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(5,006 Views)
