Cannot get database insert tool to work
Error -2147217900 occurred at Cmd Execute.vi->DB Tools Insert Data.vi->DB_SAVE_UTILITY.vi->Tracking_Screen.vi
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Microsoft Access Driver] Syntax error in INSERT INTO statement. in Rec Create - Command.vi->Cmd Execute.vi->DB Tools Insert Data.vi->DB_SAVE_UTILITY.vi->Tracking_Screen.vi
I keep getting the above error. I have a cluster wired into the data terminal. I have insured that all items in the cluster are the same data types as the database except the date/time data type in the database. The data/time is set to "now" in the table design so I don't think I should have to right to it, but if I don't have a place in my cluster it returns that it is the wrong size instead of the above error. Any suggestions?
(3,071 Views)
Hi SeverCorr,
Please refer to the following KnowledgeBase article titled LabVIEW Error -2147217900 When Trying to Insert Data Into an Access Database.  If the listed solution does not solve your problem, could you please attach a simple section of code that generates this error, along with your database file?
(3,046 Views)
