Cannot get signals of potentiometer
The terminal block is exactly what it says. You simply cannot use this dumb device by itself.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/3397
Message 11 of 15
(787 Views)
Thanks for the added info, but the 1315 is just a terminal block. It needs to be connected to a device that performs the actual acquisition. What is it screwed into?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 15
(768 Views)
Yes, It is screwed into 1540, which has 8 channels for LVDTs. Sorry for the confusing, I am a beginner of using Labview from civil engineering. I really got confused by the channels, wires and terminology.
Message 13 of 15
(754 Views)
Thanks. I just checked, the terminal block was indeed screwed into 1540.
Message 14 of 15
(752 Views)
I think I worked it out. Repaired some wires and reconnected the channels to terminals, and reset the maximum and minimum limits. Seems like I got reasonable data.
Thanks.
Message 15 of 15
(735 Views)
