Cannot get the output of ultrasonic sensor using arduino sensor
I have configured the vi and using ultrasonic sensor I am not able to get the output the output is 0 every time and I have made correct connection with arduino I have attached the vi Can anyone please help mee.....
(926 Views)
Hi harsha,
which sensor (type, manufacturer) do you use?
Did you verify the correct conneciton of Arduino and this sensor?
Can you read the sensor using the usual Arduino IDE?
(901 Views)
