Cannot go to Select Functions to Convert windows for Import Shared library dll
As you can see the steps below, i cannot go throgh the Select Function to Convert windows after i click next on Configure Include path steps.
any idea why is this happening?
i am using Labview 8.5 and WinXP OS.
(2,812 Views)
It would help if you provided the DLL and the header file.
Also, I think the third screenshot was intended to be something else, since it's the step where you specify any additional header files to reference, and not the step where you select what functions to import.
(2,792 Views)
